how to get rid of or change top picture and invitation to help someone else sign up?
  • 3 have this problem
  • 3 views
  • Last reply by cor-el
I don't like the top picture and would like to delete it or change it. I don't like the permanent invitation when first opening up firefox, to invite someone else to down load it, and would like to delete it.
You can uninstall your current Persona and revert to the Default theme (Tools > Add-ons > Themes).
See:
If you have problems with removing the persona then see:
Modified by cor-el
